I am using Ubuntu 14.04 and trying to install opencv 3.3.0. While I execute cmake to get the make files, it is not able to locate the Python interpreter, displaying the following message (though the cmake proceeds)
    -- Could NOT find PythonInterp: Found unsuitable version "2.7.6",
       but required is at least "3.4" (found /usr/bin/python)
       but required is at least "3.2" (found /usr/bin/python)
When I check /usr/bin/ , I could see python libraries/binaries present there (found in the image below)
I could also see the following versions of python
 python             python2.7-config   python3.4          python3.4m-
 config  python3.5m-config  python3m-config
 python2            python2-config     python3.4-config   python3.5
 python3-config     python-config
 python2.7          python3            python3.4m         python3.5m
 python3m           python-mkdebian
How can I solve this? Due to this issue, I am not able to use cv2 in my python script, as it throws the following error
    ImportError: No module named 'cv2'
/usr/bin/python
is a symlink.
Try
ls -l /usr/bin/python
It's probably pointing to python2.7
You need to do (as root)
ln -f -s /usr/bin/python3.4 /usr/bin/python
This will delete the old symlink (because of the -f) and make a new one pointing to python3.4.
Unfortunately there are some incompatibilities between python version 2 and python version 3, so the above instructions may break some other applications. If you see that problem, you might try upgrading your version of cmake. cmake seems to look for a python interpreter using a list in the file
/usr/share/cmake-<version>/Modules/FindPythonInterp.cmake
If you have an older version of this file which contains a line like
set(_PYTHON3_VERSIONS 3.3 3.2 3.1 3.0)
you could try editing it to
set(_PYTHON3_VERSIONS 3.4 3.3 3.2 3.1 3.0)
I haven't tried this myself as I have a newer version of cmake, but it should be worth a try.
rparkins
  • 19
