Is there some command to search a directory for files and output the result to a file with a prefix text before name of file that was found?
For example, I have a directory with these files:
sound1
sound2
sound3
Then give a command to search the directory and write the results to a text file with a prefix before it, e.g.
media sound1
media sound2
media sound3
Bonus question
Is there a way to write "media1", "media 2" etc... instead of just "media" to an existing text file without deleting what was inside that text file before?
media1 sound1
media2 sound2
media3 sound3
dessert
  • 40,956
joblade
  • 61
5 Answers5
How about a simple for loop?
for i in *; do echo media $i >> text_file; done
Explanations
  • * – expands to every file in the current directory
  • echo media $i – prints “media ” and the currently processed filename
  • >> text_file – redirects the output of echo to a file called text_file appending it
Example
$ ls
sound1  sound2  sound3
$ for i in *; do echo media $i >> text_file; done
$ cat text_file
media sound1
media sound2
media sound3
Bonus question
k=0; for i in *; do ((k++)); echo media$k $i >> text_file; done
Or for very many files (slightly faster):
j=text_file; k=0; for i in *; do if [[ "$i" != "$j" ]]; then ((k++)); echo media$k $i; fi; done > "$j"
Explanations
  • k=0 – define variable k and set it to 0
  • ((k++)) – increment $k by one
Example
$ ls
$ k=0; for i in *; do ((k++)); echo media$k $i >> text_file; done
$ cat text_file
media1 sound1
media2 sound2
media3 sound3
dessert
  • 40,956
This aught to help:
find /path/to/sound/files -type f -name "sound[0-9]" -printf 'media %f\n' > file.txt
Information:
sound[0-9]: Look for file with names that have sound and ends with a number
-printf 'media %f\n': Format the filesname with a prefix of media.
> file.txt: Send it to file called file.txt.
George Udosen
  • 37,534
You can use find command in this way:
find . ! -name 'sound.txt' -type f -exec sh -c 'echo "media $(basename {}) "' \; > sound.txt
Explanation:
  • The first argument is the path to the directory, in the example this is the current directory ., but you can change it to /any/desired/path/.
  • ! -name 'sound.txt' - means that items with name sound.txt will be omitted.
  • -type f - means only files will be finding.
  • -exec <command> \; - instruct the find command to execute <command>.
  • {} is the output argument from the entire command before -exec - find . ! -name 'sound.txt' -type f.
  • sh -c 'echo "media $(basename {}) "' is the <command> that will be executed:
    • sh -c - execute a command within /bin/sh shell;
    • 'echo "media $(basename {}) "' - command to be executed:
    • echo "<something>" - output <something> to STDOUT;
    • media - just a string;
    • $(<some command>) - treat the result of <some command> as string;
    • basename {} - print only the filename without its path, where {} is the variable that contains the full filename generated by find . ! -name 'sound.txt' -type f
  • Finally > redirects STDOUT;
  • sound.txt is the name of the file where STDOUT will be redirected.
Update from the comments. Within the comments there are two suggestions for simplification of the above command:
  • The initial command:
  • Dessert's suggestion:
    find . ! -name 'sound.txt' -type f -exec sh -c 'echo media ${0##*/}' {} \;
  • Steeldriver's suggestion:
    find . ! -name 'sound.txt' -type f -printf 'media %f\n'
Example of usage. Let's assume we have a directory with the following structure:
$ tree .
├── sound
├── sound1
├── sound2
├── sound3
├── sound4
├── sound5
├── sound99
└── soundd
The outputs of each of the above command will be identical each other:
$ find . ! -name 'sound.txt' -type f -printf 'media %f\n'
media sound1
media soundd
media sound3
media sound5
media sound2
media sound
media sound99
media sound4
Bonus question. According to the bonus question, the find command isn't the best choice, but its output could be piped (|) to another command or cycle. And here are two cases:
  • The first case is when we want to just count the media# results:
    find . ! -name 'sound.txt' -type f -printf 'media %f\n' | sort | \
    while read -r i; do \
        count=$((count+1)); \
        echo $i | sed "s/media/media$count/"; \
    done
    The example output of this command will be:
    $ find . ! -name 'sound.txt' -type f -printf 'media %f\n' | sort | while read -r i; do count=$((count+1)); echo $i | sed "s/media/media$count/"; done
    media1 sound
    media2 sound1
    media3 sound2
    media4 sound3
    media5 sound4
    media6 sound5
    media7 sound99
    media8 soundd
  • The other case is when we want to assign the number of each sound# file to its media prefix. And because into the example's circumstances has two files without any number within their names (sound, soundd), we shall add unique number to them, so the prefix will be media/#:
        number=$(echo $i | grep -Eo '[0-9]+'); \
        if [ -z $number ]; then \
            count=$((count+1));
            number="\/$count"; \
        fi; \
        echo $i | sed "s/media/media$number\t/"; \
    done
    Or we can use this more simple syntax:
        [ -z $number ] && count=$((count+1)) && number="\/$count"; \
    done
    $ find . ! -name 'sound.txt' -type f -printf 'media %f\n' | sort | while read -r i; do number=$(echo $i | grep -Eo '[0-9]{1,99}'); [ -z $number ] && count=$((count+1)) && number="\/$count"; echo $i | sed "s/media/media$number\t/"; done
    media/1  sound
    media1   sound1
    media2   sound2
    media3   sound3
    media4   sound4
    media5   sound5
    media99  sound99
    media/2  soundd
  • Hints:
    • You can copy and paste a multi line command directly to the terminal.
    • Don't forget > sound.text into the end of the command to push the output into a file.
    • Wired topic.
pa4080
  • 30,621
First print the list of files (one entry per line) in a file (list_of_files)
ls -1 /location/of/the/directory > list_of_files
Then add a fixed prefix (media) to each line
sed -i 's/^/media /' list_of_files
Update for bonus question
To add numbering, first print the list of files in a file (say list_of_files) as before. Then add line numbers before each line
sed -i '=' list_of_files
The output would look like this
sound1
sound2
Then fix the line-breaks
sed -i '{N;s/\n/ /}' list_of_files
The output would now look like this
1 sound1
2 sound2
Then finally add a fixed prefix (media) to each line like before
sed -i 's/^/media/' list_of_files
Final output would be
media1 sound1
media2 sound2
pomsky
  • 70,557
Try this script:
#!/bin/bash
dir=`find /home/username/ -name script_test`
ls $dir  > test.txt
sed -i -e 's/^/media /' test.txt
Eliah Kagan
  • 119,640
Beginner
  • 491
