I'm unable to launch google-chrome-stable. This is the error I am getting:
[4604:4640:0929/093415.646539:FATAL:nss_util.cc(632)] NSS_VersionCheck("3.26") failed. NSS >= 3.26 is required. Please upgrade to the latest NSS, and if you still get this error, contact your distribution maintainer.
Aborted (core dumped)
People suggest if you are running an older version of ubuntu it won't work but I am on 16.04
I have been looking online and have tried all the different suggestions e.g. to perform security updates.
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ sudo apt-get install libnss3
However if I run $ apt-cache policy libnss3 I get the following:
libnss3:
Installed: 2:3.21-1ubuntu4
Candidate: 2:3.21-1ubuntu4
Version table:
*** 2:3.21-1ubuntu4 500
500 http://de.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
100 /var/lib/dpkg/status
EDIT
After running sudo apt update && sudo apt full-upgrade
output related to google chrome:
Ign:19 http://dl.google.com/linux/chrome/deb stable InRelease
Get:20 http://security.ubuntu.com/ubuntu xenial-security InRelease [102 kB]
Hit:21 http://dl.google.com/linux/chrome/deb stable Release
Fetched 102 kB in 7s (13.9 kB/s)
Reading package lists... Done
Building dependency tree
10 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: http://repo.acestream.org/ubuntu/dists/trusty/InRelease: Signature by key E1254F21D636B7EFDE41D2AF50E2BCF0E3805CD8 uses weak digest algorithm (SHA1)
Calculating upgrade... Done
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/65.3 MB of archives.
After this operation, 146 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 403416 files and directories currently installed.)
Preparing to unpack .../google-chrome-stable_61.0.3163.100-1_amd64.deb ...
Unpacking google-chrome-stable (61.0.3163.100-1) over (61.0.3163.79-1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up google-chrome-stable (61.0.3163.100-1) ...
I am still seeing the same error message after this after a restart
