I'm trying to install GoAccess (https://goaccess.io) on Ubuntu 16.04.2 LTS, I was following this tutorial - https://www.vultr.com/docs/how-to-install-goaccess-on-ubuntu-16-04
So when I entered following command -
sudo apt-get -y upgrade
it throws me following errors -
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 linux-image-extra-4.4.0-75-generic : Depends: linux-image-4.4.0-75-generic but it is not installed
 linux-image-extra-4.4.0-96-generic : Depends: linux-image-4.4.0-96-generic but it is not installed
 linux-image-generic : Depends: linux-image-4.4.0-96-generic but it is not installed
                       Recommends: thermald but it is not installed
E: Unmet dependencies. Try using -f.
Then I tried the following command -
sudo apt-get -f install
But it ends with an error which is -
 /var/cache/apt/archives/linux-image-4.4.0-96-generic_4.4.0-96.119_amd64.deb
 /var/cache/apt/archives/linux-image-4.4.0-75-generic_4.4.0-75.96_amd64.deb
So I thought to install the dependencies seprately, and executed following command -
sudo apt-get -f install linux-image-4.4.0-75-generic linux-image-extra-4.4.0-75-generic linux-image-4.4.0-96-generic
but this command ended up with following error -
Unpacking linux-image-4.4.0-75-generic (4.4.0-75.96) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-75-generic_4.4.0-75.96_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-4.4.0-75-generic' to '/boot/vmlinuz-4.4.0-75-generic.dpkg-new': failed to write (No space left on device)
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-75-generic /boot/vmlinuz-4.4.0-75-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-75-generic /boot/vmlinuz-4.4.0-75-generic
Can anybody help me on this? Thanks
Musa
  • 101
Actually I found the answer, it was lack of space in boot. This is the answer that worked for me - https://askubuntu.com/a/171225/742040
Musa
  • 101
