I can't find a program I wanted from the software centre, so had to download a tar file, but it wont install. Do I have to have a degree in physics or coding just to get it to install? I can't understand why a mouse click wont start the install process? I've tried to figure out the 'compile' etc commands, but I can't do it. Thanks
Mr Rush every in learn has to be given some period to understand it. When installing using a tar file we have to follow certain steps to get it installed:
Download the
tarfileUntarit withtar -xvf finename.tarChange into the
untarredfile and inside you will find aREADMEfile to direct you on how to install the application as was intended or designed by the owners.For
step 3we may see a simple install script that we may have to makeinstallable(depending on whether that has already been done by the creators), from our terminal using the command:chmod u+x install.sh- Note that it can be called anything or even lack a file
extension
But ofcourse the
tarfile can be untarred byright clickingon it with your mouse and selectingExtra here.
Now to answer your click issue, Ubuntu comes with .deb package file that are installed using the mouse click, if you are asked to use a tar file then it's the creators fault and not Ubuntu. They were too lazy or busy to create a .deb package file. They alone can say why they prefer tar file rather than .deb files.
- 37,534
