I want to make caps lock as control key, so I wrote this setxkbmap -option caps:ctrl_modifier to my bashrc file. The problem is that after I log in the next time or restart the system, nothing happened. Caps lock is still caps lock... So how to change caps lock to control key?
Daniel
To make that change system wide and persistent, open /etc/default/keyboard for editing, change the line
XKBOPTIONS=""
to
XKBOPTIONS="caps:ctrl_modifier"
and reboot.
~/.bashrcscript just change defaults at terminal session, and it doesn't extend to other areas of your environment. To make this, you could create a script file with this command in it, as:
#!/bin/sh
/usr/bin/setxkbmap -option caps:ctrl_modifier
Then you add it to your sesssion startup manager, as you can see here
Redbob
  • 1,686
I assigned the command to ~/.profile and it works. Now I see that ~/.bashrc script just change defaults at terminal session, people who are fresh to linux like me should notice this too. Thank you guys!
Daniel
