I would like to know more about this command:
sudo apt-get dist-upgrade
See man apt-get:
dist-upgrade
dist-upgrade in addition to performing the function of upgrade, also intelligently handles changing
dependencies with new versions of packages; apt-get has a "smart" conflict resolution system, and it will
attempt to upgrade the most important packages at the expense of less important ones if necessary. The
dist-upgrade command may therefore remove some packages. The /etc/apt/sources.list file contains a list of
locations from which to retrieve desired package files. See also apt_preferences(5) for a mechanism for
overriding the general settings for individual packages.
To learn about commands, read their manual page (short "manpage") using the man command.
E.g. to learn about apt-get, type this command:
man apt-get
The manual will also contain a description of the dist-upgrade argument:
dist-upgrade
also intelligently handles changing dependencies with new versions
it will attempt to upgrade the most important packages at the
expense of less important ones if necessary. The dist-upgrade
/etc/apt/sources.list file contains a list of locations from which
a mechanism for overriding the general settings for individual
packages.
To exit the manual viewer again, simply press Q.
The sudo is needed because the command needs root privileges in order to perform the necessary system-wide operations.
