I have recently made my Intel NUC7I3BNH machine dual boot, originally with Ubuntu 16.04 and recently added Ubuntu 14.04. Everything works as expected, except that I've tried dozens of solutions but simply cannot get my wired or wireless connections to work. It sounds like it's a driver issue, because this is the output to ifconig -a:
    lo          Link encap:Local Loopback
                inet addr:127.0.0.1 Mask:255.0.0.0
                inet6 addr: ::1/128 Scope:Host
                UP LOOPBACK RUNNING MTU:65536 Metric:1
                RX packets:16 errors:0 dropped:0 overruns:0 frame:0
                TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:1
                RX bytes:1184 (1.1 KB) TX bytes:1184 (1.1 KB)
I say it might be a driver issue because eth0 doesn't appear at all, but I could be very wrong as I am somewhat inexperienced at this kind of stuff. Some other information:
  • Ubuntu 16.04 runs perfectly after installation (wired and wireless connections function as expected)
  • The internet connectivity issue lies within Ubuntu 14.04
  • Under "Software & Updates --> Additional Drivers", the system says there are "no additional drivers available". This is true after also the "Software & Updates --> Ubuntu Software" tab recognizes there is a "Installable from CD-ROM/DVD" option because I provided the .iso file I used to install Ubuntu 14.04 in the first place.
EDIT
This is the output I get from sudo lshw -C network under 16.04:
*-network
    description: Intel Corporation
    product: Intel Corporation
    physical id: 0
    bus info: pci@0000:3a:00.0
    logical name: wlp58s0
    version: 78
    serial: f8:63:3f:0f:de:03
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
    configuration: broadcast=yes driver=iwlwifi driverversion=4.10.0-35-generic firmware=22.391740.0 ip=192.168.1.173 latency=0 link=yes multicast=yes wireless=IEEE 802.11
    resources: irq:128 memory:dc100000-dc101fff
*-network
    description: Ethernet interface
    product: Ethernet Connection (4) I219-V
    vendor: Intel Corporation
    physical id: 1f.6
    bus info: pci@0000:00:1f.6
    logical name: eno1
    version: 21
    serial: f4:4d:30:6b:13:dd
    capacity: 1Gbit/s
    width: 32 bits
    clock: 33MHz
    capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.1-4 latency=0 link=no multicast=yes port=twisted pair
    resources: irq:125 memory:dc200000-dc21ffff
This is the output I get from modinfo iwlwifi | head -n20 under 16.04:
filename:      /lib/modules/4.10.0-35-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:       GPL
author:        Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description:   Intel(R) Wireless WiFi driver for Linux
firmware:      iwlwifi-100-5.ucode
firmware:      iwlwifi-135-6.ucode
firmware:      iwlwifi-105-6.ucode
firmware:      iwlwifi-2030-6.ucode
firmware:      iwlwifi-2000-6.ucode
firmware:      iwlwifi-5150-2.ucode
firmware:      iwlwifi-5000-5.ucode
firmware:      iwlwifi-6000g2b-6.ucode
firmware:      iwlwifi-6000g2a-6.ucode
firmware:      iwlwifi-6050-5.ucode
firmware:      iwlwifi-6000-6.ucode
firmware:      iwlwifi-7265D-26.ucode
firmware:      iwlwifi-7265-17.ucode
firmware:      iwlwifi-3168-26.ucode
firmware:      iwlwifi-3160-17.ucode
This is the output I get from sudo lshw -C network under 14.04:
*-network UNCLAIMED
    description: Network Controller
    physical id: 0
    version: 78
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress cap_list
    configuration: latency=0
    resources: memory:dc100000-dc101fff
*-network UNCLAIMED
    description: Ethernet controller
    physical id: 1f.6
    version: 21
    width: 32 bits
    clock: 33MHz
    resources: memory:dc200000-dc21ffff
This is the output I get from modinfo iwlwifi | head -n20 under 14.04:
filename:      /lib/modules/4.4.0-31-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:       GPL
author:        Copyright(c) 2003- 2015 Intel Corporation <iwl@linux.intel.com>
firmware:      iwlwifi-6000-4.ucode
firmware:      iwlwifi-7265D-13.ucode
firmware:      iwlwifi-7265-13.ucode
firmware:      iwlwifi-3160-13.ucode
firmware:      iwlwifi-7260-13.ucode
Your wired networking issue:
If you are having this issue with a fresh install of 14.04.3 it's because the Ubuntu 14.04.3 LTS installation kernel doesn't support the Intel i219V gigabit controller.
Options:
A) You can build your own driver as described here.
B) You can install a pre-built driver downloadable from here
Place the downloaded driver on a flash drive so that you can access it when you boot 14.04 and copy it to the appropriate location with the command:
sudo cp /path/to/flashdrive/e1000e.ko /lib/modules/$(uname -r)/kernel/drivers/net/ethernet/intel/e1000e
next issue the command sudo depmod -a
Note:
depmod creates a list of module dependencies by reading each module under /lib/modules/version and determining what
       symbols it exports and what symbols it needs. By default, this list is written to modules.dep, and a binary hashed
       version named modules.dep.bin, in the same directory. If filenames are given on the command line, only those modules are
       examined (which is rarely useful unless all modules are listed).  depmod also creates a list of symbols provided by
       modules in the file named modules.symbols and its binary hashed version, modules.symbols.bin. Finally, depmod will output
       a file named modules.devname if modules supply special device names (devname) that should be populated in /dev on boot
       (by a utility such as udev).
Reboot 14.04 and confirm that the NIC is up either with the command ifconfig or utilizing the option on the title bar in the upper right corner of your screen as shown below:
Connection info
Now that you have verifed connectivity you can simply update your system as usual with
sudo apt-get update
sudo apt-get upgrade
Note: I do not have your hardware nor have I installed kernel 4.4.0-31-generic under 14.04 and cannot test this as both would be required. It should work as advertised on a fresh install of 14.04.3
Further useful information: https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005480.html
Sources:
http://faq.aslab.com/support/kb/231.html
Ethernet not working on ubuntu 14.04 LTS
Elder Geek
  • 36,752
