Is there any way to sync iphone in ubuntu 16.04 LTS.
Please help!
I've found all this information in this website: http://geeknizer.com/sync-iphone-linux/
Maybe you can try this:
Step 1. Add Repository:
sudo add-apt-repository ppa:pmcenery/ppaand Update the Apt source list
sudo apt-get updateStep 2. Next, we install all the required packages:
sudo apt-get install gvfs gvfs-backends gvfs-bin gvfs-fuse libgvfscommon0 ifuse libgpod-dev libgpod-common libiphone-utils libiphone0 python-iphone libplist++1 libplist-utils python-plist libusb-1.0-0 libusb-1.0-0-dev libusbmuxd1 usbmuxdStep 3. Let’s Configure Fuse, our interfacing component. Edit fuse.conf file
gksudo gedit /etc/fuse.confChange
#user_allow_otherto
user_allow_otherSave and exit.
Step 4. Next, We modify your user for Fuse so that it can Auto-mount iPhone/iPod Touch on every boot.
Navigate to “System” -> “Administration” -> “Users and Groups”, click on the little key at bottom to unlock it for making changes. Then, select your username (
<fx>for me) and click on “Manage Groups”.Lookout for “fuse” group, double-click it. Tick the checkbox next to your name in the new popup window. Click on OK and close all dialogs. You’re now in the “fuse” group.
Step 5. Alright, now log out and in again (Reboot is always better)
When you are back into the session, mount the phone as:
$ ifuse /mnt/ipod/We can also unmount using the following command
$ fusermount -u /mnt/ipod/Step 6. Let’s prepare ipod itunes directory:
$ mkdir /mnt/ipod/iTunes_Control/Device/Fetch your UUID (The first number, 40 characters long)
$ lsusb -v | grep -i iSerialThen, run:
$ ipod-read-sysinfo-extended[mountpoint here is /mnt/ipod/]
This should generate a file named iTunes_Control/Device/SysInfoExtended.
Make sure it’s not empty and should be a big plist (XML file) with a bunch of info.
$ fusermount -u /mnt/ipod/Reboot.
Step 7. Hold your breath and Plug the iPod/iPhone, you should see it appear on the desktop and it should now be:
- Mounted as-is in Rhythmbox and you can add music files. (it can be slow)
- Mounted in gtkpod but you’ll have to launch the “ifuse /mnt/ipod”.
*Rhyhmbox is unable to remove music files, use the gtkpod to remove files or add videos to the iPhone.
Read more:
