I have a media and PVR server running ubuntu 16.04 that sporadically loses its wired connectivity (the IP drops off the ifconfig output; the icon on the desktop indicates that it's connected but it's not). The interface is dhcp, but is statically assigned from the router. If I don't catch that it's down for hours or days, I miss recording shows onto it (which saddens the wife).
After reading numerous approaches across askubuntu and elsewhere, my solution was going to be simply to add "ifup -a" to cron.hourly. Is there a performance hit or any other impacts of doing this? Is there a better or "approved" way of checking and restarting network interfaces automatically? I don't know why it drops in the first place-- the wire stays connected and the machine is directly connected to my main (unmanaged) switch.
/etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
auto enp0s10
iface lo inet loopback
iface enp0s10 inet dhcp
One solution would be to actually check to see if the interface is up first and then restart the network-manager service if it's not with a script like the following. This checks to see if a single ping
if ! ping -Q 1 -c 1 -t 60 google.com; then
echo warning: lost network connection >>/var/log/syslog
    service network-manager restart
fi
and launch that with cron at whatever period of time you think is sufficient.
You may want to boost the -Q parameter as discussed here if you don't get the desired results but it worked fine at 1 in my tests. you might also have to tweak the -t parameter to suit your environment.
Of course you'll have to setup the cron job properly for this to work.
Sources:
https://unix.stackexchange.com/questions/133931/automatically-restarting-network-connection
man ping
How to set up a root cron job properly
Testing.
Elder Geek
  • 36,752
