I follow the ROS Kinetic Install Tutorial on my ubuntu16.04,but i met the problem while
elon@elonWorkStation:~/Script$ sudo apt-get install ros-kinetic-desktop-full
Reading package lists... Done
Building dependency tree
 ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going to be installed
                            Depends: ros-kinetic-perception but it is not going to be installed
                            Depends: ros-kinetic-simulators but it is not going to be installed
                            Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
I have try every method I can find but no luck. This is my /etc/apt/sources.list
deb http://mirrors.aliyun.com/ubuntu/ xenial universe restricted multiverse
I have worked on the problem for about a day. I can I fix it.
INFO: I have recently updated to Ubuntu 18.01 bionic, I am also trying to install ros melodic.
SHORT ANSWER:
For me it worked to install libcurl4, libcurl4-openssl-dev
LONG ANSWER:
Hi,
I have got the same problem that you, which make me feel better that I amnot alone. The one way around is to use the installation from source http://wiki.ros.org/melodic/Installation/Source. Then, they provide a tool called rosdep that can be used to resolve dependencies:
rosdep install --from-paths src --ignore-src --rosdistro melodic -y
EDIT: If trying to install kinetic must be: kinetic
And then the error contained more information such as that libcurl4, and libcurl4-openssl-dev were missing. I installed. sudo apt-get install libcurl4 sudo apt-get install libcurl4-openssl-dev
And then changed to install again the recommended version in: http://wiki.ros.org/melodic/Installation/Ubuntu
I have been digging in the internet and could not been able to find any other fixing that work for me.
Regards,
