I'm new to the Ubuntu OS and I want to be able to run it in ANY way I can.
I made a bootable USB (not persistent) to install Ubuntu. Followed the instructions in the install, had made a partition of 35 GB before, installed it with everything going smoothly. Restarted the computer and wasn't able to boot it. I looked it up and found that I had to turn off Secure Boot (did it) and use the Boot Repair tool, used it and nothing happened.
Also tried doing a live USB with persistence to at least be able to run Ubuntu in a 16 (or 32 GB) but is not kept persistent.
Does anyone have any suggestions or can provide help?
You can find my Boot-Repair report at the link below:
If anyone finds this and haven't found any solution, try this:
Just as MichaelBay suggested, make sure everything is set to UEFI, turn off Legacy. In BIOS options enable Secure Boot. Go to Security Tab and select Add file to Secure Boot(someting like that) then loop through the files that are shown and look for ubuntu file. Select it and save changes, restart computer and boot the Boot Options Menu(F12) and the file you jut added should be shown.
Carlos F
  • 121
Made it work. But none of the post I found about creating it in UEFI worked(because I had already created it in UEFI). It is ineed importat that you verify that if you want to boot it in UEFI, you install it in UEFI.
What I did different was that I had to turn on Enable Secure Boot in BIOS
Go to Security Tab
Gent to the Secure Boot options
Add file to secure boot(something like that)>EFI>ubuntu> Save changes
Restarted machine didn't boot instantly(even though the order is arranged) so I pressed F12> chose ubuntu and done.
Carlos F
  • 121
