I just installed Ubuntu 16.04 LTS, and because I want to use my Chromecast I think I'll need Chrome or Chromium.
The the software-center ("store") doesn't launch.
So I pasted the line sudo apt-get install chromium in the terminal and entered my password.
chromium-bsu:i386 chromium-bsu
I obtained the following text:
Reading package lists... Done
Building dependency tree
Package chromium is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
E: Package 'chromium' has no installation candidate
So I pasted chromium-bsu:i386 chromium-bsu
but got this answer:
chromium-bsu:i386: command not found
What now?
I also downloaded the installation file of Chrome,
google-chrome-42-0-2311-90-32-bit-multi-ubu.deb
but nothing happens when I double-click it
I was a Windows user, so I don't know what to do.
Eliah Kagan
  • 119,640
Chromium web browser (chromium-browser) is an open-source version of Google Chrome. Open the terminal and type:
sudo apt install chromium-browser
To install the Chrome .deb file that you downloaded change directories using cd to the directory that contains google-chrome-42-0-2311-90-32-bit-multi-ubu.deb and run the following command:
sudo apt install ./google-chrome-42-0-2311-90-32-bit-multi-ubu.deb
dpkg -i suggested by Cynplytholowazy also installs the same Chrome .deb file, but it doesn't do any automatic dependency resolution as the above command, which uses apt instead of dpkg, does.
karel
  • 122,292
  • 133
  • 301
  • 332
Don't paste chromium-bsu:i386 unless you have i386 architecture enabled. chromium-bsu:i386 is the 32-bit version of chromium-bsu package.
Note that chromium-bsu is a game though, you should install chromium-browser instead.
Simply just type:
sudo apt-get install chromium-browser
and you will get Chromium installed. Note that it is 64-bit.
As for the installation of Google Chrome, you can install it using:
sudo dpkg -i ~/Downloads/google-chrome-42-0-2311-90-32-bit-multi-ubu.deb
Assuming you have your installation file in the folder /home/(user)/Downloads.
