Attempting to launch VirtualBox in Ubuntu 16.04 produces an error about the vboxdrv module not being able to load, then another error about /usr/lib/virtualbox/VirtualBox not being found.
$ virtualbox
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
         available for the current kernel (4.10.0-35-generic) or it failed to
         load. Please recompile the kernel module and install it by
           sudo /sbin/vboxconfig
         You will not be able to start VMs until this problem is fixed.
/usr/bin/virtualbox: 111: exec: /usr/lib/virtualbox/VirtualBox: not found
To obtain VirtualBox, I downloaded the .deb file from the website and installed it from local using:
sudo dpkg -i virtualbox5.1_5.1.28-117968~Ubuntu~xenial_i386.deb
Russo
  • 1,908
I've had exactly the same problem on ubuntu 17.04 amd64 with kernel 4.10.0-35-generic. FIxed with the following line:
apt --fix-broken install
apt installed then libqt5x11extras5. Hope this will help.
From information originally provided in comments, it appears your system is a 64-bit system and you're using a 32-bit VirtualBox installer. Please re-download the 64-bit version for your Ubuntu system.
Eliah Kagan
  • 119,640
George Udosen
  • 37,534
