When I try sudo apt-get update && sudo apt-get install sysstat I get the following:
sysstat : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
As far as I can tell, there are no held broken packages. I've tried a bunch of other things, like:
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt-get update
Any help would be great!
