I tried to install dlib using:
pip install dlib
It appeared to be working, but then I got an error message. Here it is:
Collecting dlib
  Using cached dlib-19.7.0.tar.gz
Building wheels for collected packages: dlib
  Running setup.py bdist_wheel for dlib ... done
  Stored in directory: /home/andrew/.cache/pip/wheels/17/1f/5d/187f5a9fc1d63527e97fa08f5f43315e72a7b7c2ebc54e02e3
Successfully built dlib
Installing collected packages: dlib
Exception:
Traceback (most recent call last):
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/req/req_set.py", line 784, in install
**kwargs
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/req/req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/wheel.py", line 316, in clobber
    ensure_dir(destdir)
  File "/home/andrew/.local/lib/python2.7/site-packages/pip/utils/__init__.py", line 83, in ensure_dir
    os.makedirs(path)
  File "/usr/lib/python2.7/os.py", line 157, in makedirs
    mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/dlib'
I'm not sure why it says permission denied. Does anyone know how to resolve this error?
Andrew
Use
sudo pip install dlib
And make sure you have cmake installled in your ubuntu and configured
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
