The authentication window pops-up but then I'm getting a bunch of errors (in the console) and nothing happens. Looked up similar issues on the Internet and tried the following:
  • updating the OS
  • installing: python-gobject, python-gi, dev-tools
Thanks in advance for any advice.
Traceback (most recent call last):
  File "/usr/share/gufw/gufw/gufw.py", line 21, in
    from gufw.view.gufw  import Gufw
  File "/usr/share/gufw/gufw/gufw/view/gufw.py", line 18, in
    import gi
  File "/usr/lib/python3/dist-packages/gi/__init__.py", line 42, in
    from . import _gi
ImportError: cannot import name '_gi'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
    from apport.fileutils import likely_packaged, get_recent_crashes
  File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in
    from apport.report import Report
  File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in
    import apport.fileutils
  File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in
    from apport.packaging_impl import impl as packaging
  File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 24, in
    import apt
  File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in
    import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Original exception was:
    import gi
    from . import _gi
Maddak
I've encountered the same problem, and it's really not easy to find a good fix (they're really very few results on google), so my solution is to fully reinstall pygobject in accordance with https://pygobject.readthedocs.io/en/latest/getting_started.html
sudo apt install python3-gi python3-gi-cairo gir1.2-gtk-3.0
sudo apt install libgirepository1.0-dev gcc libcairo2-dev pkg-config python3-dev gir1.2-gtk-3.0
pip3 install pycairo
pip3 install PyGObject
(You need to apt install python3-pip beforehand.)
It worked perfectly for me.
lp177
Recently I faced this kind of error.
In my case I'm using Kubuntu 18.04 and the official repositories only have python 3.6.
Some time ago I installed Python 3.7 from sources (doing make install, etc...) as a requirement of a project.
When I installed Python the system overrides the default path to python3 executable with the fresh installation.
So to fixed this issue I removed the local system executable of python3 (--> python3.7) and create it again with the path to python3.6.
sudo rm -rf /usr/local/bin/python3
sudo ln -s /usr/bin/python3.6 /usr/local/bin/python3
I hope this helps someone!
Not sure what, if anything you might have done to cause this. Upgrade Ubuntu? How did you install UFW? From the repos?
At any rate , that is sort of a non-specific error and might occur with other packages as well.
As a first step try updating (“dist-upgrade”) to see if you have outdated or held packages.
sudo apt-get update
sudo apt-get dist-upgrade -f
If that fails as a second step try re-installing python-apt
See https://packages.ubuntu.com/zesty/python-apt
sudo apt-get install --reinstall python-apt
You could shorten those two commands, but I hope it is more clear to demonstrate the reinstallation of python-apt.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Panther
  • 104,528
