I have unmet dependencies so my upgrade command fails with:
You might want to run 'apt-get -f install' to correct these:
 linux-image-extra-3.19.0-80-generic : Depends: linux-image-3.19.0-80-generic but it is not going to be installed
 linux-image-generic-lts-vivid : Depends: linux-image-3.19.0-80-generic but it is not going to be installed
                                 Recommends: thermald but it is not going to be installed
the problem is that I have full boot partition so apt-get -f install fails.
Unpacking linux-image-3.19.0-80-generic (3.19.0-80.88~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.19.0-80-generic_3.19.0-80.88~14.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-3.19.0-80-generic' to '/boot/vmlinuz-3.19.0-80-generic.dpkg-new': failed to write (No space left on device)
I tried to remove unused kernels with
 apt-get purge linux-image-3.19.0-25-generic
but it fails with original error - unmet dependencies.
So I have circular dependency in issues with upgrade. What is the safest way to resolve it? Is it safe to manually delete kernels from /boot?
4ybaka
  • 131
