I am in the midst of trying testdisk to recover a borked dual boot system, and have a specific question to testdisk .. it seems it doesn't like any combos I enter of Primary & Logical labeling.. and I do not get any option to label any of my partitions extended.. any ideas why?
TestDisk 7.0, Data Recovery Utility, April 2015
Christophe GRENIER <grenier@cgsecurity.org>
http://www.cgsecurity.org
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63
Partition Start End Size in sectors
D HPFS - NTFS 0 32 33 63 221 30 1024000
D HPFS - NTFS 63 221 31 21274 119 29 340748288
D HPFS - NTFS 21274 119 30 21399 102 15 2007040
D Linux 21399 134 48 28078 210 36 107302912
D Linux Swap 28078 210 37 31130 223 5 49031168
I know Windows can be my Primary.. so I set the following to P, but then the only good combo after that is to set Linux to Logical and Delete my Swap
are there any combinations that can just get me back into Windows or Linux.. if I cannot crack fixing my dualboot?
P HPFS - NTFS 0 32 33 63 221 30 1024000
P HPFS - NTFS 63 221 31 21274 119 29 340748288
P HPFS - NTFS 21274 119 30 21399 102 15 2007040
L Linux 21399 134 48 28078 210 36 107302912
>L Linux Swap 28078 210 37 31130 223 5 49031168
Structure: Bad.
Output from command suggested
label: dos
label-id: 0x4a2fec4f
device: /dev/sda
unit: sectors
/dev/sda1 : start= 2048, size= 1024000, type=7, bootable
/dev/sda2 : start= 1026048, size= 340748126, type=7
/dev/sda3 : start= 341774336, size= 2007040, type=27
/dev/sda4 : start= 343783422, size= 156334082, type=5
/dev/sda5 : start= 451086336, size= 49031168, type=82
