I know, that when I create empty catalog it has his own size:
mkdir test && du -h test
gives:
4,0K    test
But this case is another. I had catalog with 1e6 files (74 GB) on external HDD (ext4). I processed these files, saved in other catalog and deleted from this location in parallelized script. Now this catalog should be empty. So it is ok that
ls -a raw/all
print
But
du -h raw/all
gives
19M     raw/all
Without -h we have exactly 19288B. And this is also strange result:
ls -la raw/all
total 19292
drwxr-xr-x 2 daniel daniel 19746816 wrz 18 19:23 .
drwxrwxr-x 4 daniel daniel     4096 wrz 17 13:21 ..
What is going on? Is there any cache in du command? Or after processing such many files there are any rest after these files? I deleted filed by unlink in perl5 script.
Update - answers to questions from comments
ls -aiR raw/all
raw/all:
51647758 .  51647760 ..
lsof +L1
prints 44 lines but nothing connected with this catalog. But lsof gives something with numbers like 19746816.
lsof | grep raw
bash      5355                daniel  cwd       DIR               8,17  19746816   51647758 /media/daniel/f2971ccd-4841-4da3-8ce3-d9f2cc03fc27/daniel/pro/scraper/raw/all
lsof      5677                daniel  cwd       DIR               8,17  19746816   51647758 /media/daniel/f2971ccd-4841-4da3-8ce3-d9f2cc03fc27/daniel/pro/scraper/raw/all
grep      5678                daniel  cwd       DIR               8,17  19746816   51647758 /media/daniel/f2971ccd-4841-4da3-8ce3-d9f2cc03fc27/daniel/pro/scraper/raw/all
lsof      5679                daniel  cwd       DIR               8,17  19746816   51647758 /media/daniel/f2971ccd-4841-4da3-8ce3-d9f2cc03fc27/daniel/pro/scraper/raw/all
Laptop was rebooted. External drive was disconnected. But du still shows 19M.
Daniel
  • 397
Directories in ext4 filesystems grow, but don't shrink. So, if at some point it had to take up 19M for storing details of files in it, it will retain that much space even if those files were deleted. If you want to shrink a now-empty directory, delete and recreate it:
rmdir foo && mkdir foo
Or, retaining permissions:
mkdir foo2
chown --reference=foo foo2
getfacl foo | setfacl --set-file=- foo2
rmdir foo
mv foo2 foo
Source:
muru
  • 207,228
