While installing git using:
sudo apt-get install git
I got the below errors:
Reading package lists... Done
Building dependency tree
 git : Depends: liberror-perl but it is not installable
Yaron
  • 13,453
Old question with a new answer.
The problem is not always related to unsupported releases nor non installable items. Indeed is incomplete source list available on your system. Update the /etc/apt/sources.list, in my case using stretch to:
deb http://deb.debian.org/debian stretch main contrib non-free
deb-src http://deb.debian.org/debian stretch main contrib non-free
deb http://deb.debian.org/debian-security/ stretch/updates main contrib non-free
deb-src http://deb.debian.org/debian-security/ stretch/updates main contrib non-free
deb http://deb.debian.org/debian stretch-updates main contrib non-free
deb-src http://deb.debian.org/debian stretch-updates main contrib non-free
You can comment the deb-src lines if not needed, then do the standard apt update and go!
fcm
  • 211
