Hey there I tried to install latex using the follwing commands in ubuntu 16.04:
sudo apt-get install texlive-full texstudio
Then I finally came to the point with the following output:
Setting up thunderbird-locale-en (1:52.3.0+build1-0ubuntu0.16.04.1) ...
Setting up thunderbird-locale-en-us (1:52.3.0+build1-0ubuntu0.16.04.1) ...
Setting up context (2015.05.18.20150601-2) ...
Running mtxrun --generate. This may take some time... done.
Pregenerating ConTeXt MarkIV format. This may take some time...
And after waiting for 5 hours I closed the process. Unfortunately now my certain packages seem to be broken. e.g when I try to install a new package or try sudo apt-get dist-upgrade I get the following error:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure
-a' to correct the problem.
And If I try
sudo dpkg --configure -a
I came again to the endless waiting point....
Any Ideas what I can do?
Notes:
- I also have installed Miktex before does that cause some troubles?
I unfortunately cannot remove any package cause I also get:
sudo apt-get remove tex-common E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
