I have a problem related to nodejs. I have nodejs binaries here: ~/node-v8.5.0-linux-x64/ and I have a soft link that I created using: ln -s node-v8.5.0-linux-x64/ node.
In my .bashrc, I have this: export PATH=$PATH:$HOME/node/bin.
node and npm are working great when I'm normally logged in. As both of them are installed in my home, I don't need to be logged in as root to install a package globally.
But I wanted to try; so, I ran:
sudo npm install -g angular-cli
sudo node app.js
and it didn't work.
sudo: nodeĀ : command not found
I thought maybe the $PATH changes when I use sudo but then I checked it using sudo echo $PATH:
/home/dc/bin:/home/dc/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/dc/node/bin
The shell should know where to go when I type node command, but it seems it doesn't. I also tried -H, -i and -u options for sudo but none of that helps either.
Can someone please explain what's happening here?
