I am using ubuntu 16.04 and it has rtl8723be driver and does not shows wifi. I have tried all the methods stated in these 1, 2 . Also installled new drivers from https://github.com/lwfinger/rtlwifi_new.git. Any leads would be helpful.
output of lspci -knn | grep Net -A3; rfkill list
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
    DeviceName: Sanji2
    Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter [103c:81c1]
    Kernel driver in use: rtl8723be
    Kernel modules: rtl8723be
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
2: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
4rshdeep
  • 101
First attempt:
Try the commands with your installed version:
echo "options rtl8723be ant_sel=1" | sudo tee -a /etc/modprobe.d/rtl8723be.conf
sudo modprobe -rf rtl8723be
sudo modprobe -v rtl8723be
Check if you can find wifi.
If you do... just restart and it is ready.
Before go to the second attempt, try with option ant_sel=2 (and again all three commands)
Second attempt:
Go to the source folder of the package installed and uninstall it by running the command
sudo make uninstall
Then run:
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtlwifi-new-dkms
(I think it is the same package you already installed but it works for my 16.04 and it will accept updates too)
Again all the commands of the first attempt:
You should find wifi after the last command.
If not try ant_sel=2 on above options and give all the (3) commands
If it is better:
Restart and ready.
Sources (combination):
https://kharisecario.wordpress.com/2017/03/16/installing-realtek-rtl8723be-wifi-driver-for-debian/
https://ubuntuforums.org/showthread.php?t=2364060&highlight=rtl8723be
https://ubuntuforums.org/showthread.php?t=2363051&highlight=rtl8723be
koleygr
  • 177
