I don't want guest additions.
I have Virtualbox on a Windows host running Ubuntu 16.04 LTS as a guest. How do I make sure that all the guest additions are removed from the Ubuntu guest? I so far have run, in Terminal, these:
dpkg -l | grep virtualbox
Which returned: unity-scope-virtualbox
lsmod | grep -io vboxguest
Which returned: vboxguest
Although it doesn't show up as having the typical virtualbox guest additions, the Ubuntu screen size still resizes to the virtual machine's window. Is that actually a part of Ubuntu or from guest additions?
When first installed as a virtual machine, Ubuntu supports mouse pointer integration and screen (virtual machine window) resizing, which are typically from guest additions being installed.
Is there a way to remove the vboxguest kernel module as well?
Thank you.
Smiith
  • 125
From using the commands:
ii  unity-scope-virtualbox      0.1+13.10.20130723-0ubuntu1      all    VirtualBox scope for Unity
And
lsmod | grep vboxguest
vboxguest   282624  6 vboxsf,vboxvideo
Since you want to remove these packages do as follows:
  1. modules vboxguest:
    • Change into /opt/VBoxGuestAdditions-<version_number> folder
      cd /opt/VBoxGuestAdditions-<version_number>
    • In there run:
      sudo ./uninstall.sh
  2. For the guest additions unity-scope-virtualbox:
    sudo dpkg-query -s unity-scope-virtualbox
    Package: unity-scope-virtualbox
    Status: install ok installed
    Priority: optional
    Section: gnome
    Installed-Size: 77
    Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
    Architecture: all
    Version: 0.1+13.10.20130723-0ubuntu1
    Replaces: unity-lens-vm
    Provides: unity-lens-vm
    Depends: python3, python3-gi, gir1.2-unity-5.0 (>= 7), gir1.2-dee-1.0 (>= 1.2.5), unity-scopes-runner, gir1.2-glib-2.0
    Conflicts: unity-lens-vm
    Description: VirtualBox scope for Unity
    This package contains the "virtualbox" scope which allows Unity
    to search for VirtualBox content.
    Original-Maintainer: David Callé <davidc@framli.eu>
    Homepage: https://launchpad.net/unity-scope-virtualbox
    • This is used by unity for search and probably be left alone.
George Udosen
  • 37,534
