There has been a consistent problem with downloading videos from youtube using youtube-dl.
The filename has random characters at the end.
e.g, original filename of the video is Scala Monads: Declutter Your Code With Monadic Design
but the filename of video after downloading is Monads - Declutter Your Code With Monadic Design-Mw_Jnn_Y5iA.f136.mp4
here is the warning during download:
WARNING: Requested formats are incompatible for merge and will be merged into mkv.
it will be really helpful if somebody could suggest a solution.
Simple, use this in your command -o '%(title)s.%(ext)s' see here
https://github.com/rg3/youtube-dl/blob/master/README.md#output-template
To set as your default create this folder/file .config/youtube-dl/config
Just add the option to that file on single line, info see here
https://github.com/rg3/youtube-dl/blob/master/README.md#configuration
doug
  • 17,212
