When using any application that accepts pen input via a bamboo ink stylus if the cursor is on one side of the screen and I bring the pen down to touch the screen, the cursor will behave as though I dragged a mouse from where the pointer was to where I placed the stylus down. As shown in this picture: screenshot
I have tested this behavior and it happens in all of the following applications I have tested:
  • GIMP
  • Krita
  • Xournal
It also exhibits behavior similar to the above (dragging mouse across the screen) in the following applications not intended for pen use:
  • Unity Desktop
  • Google Chrome
  • Entire LibreOffice Suite
I have not found or installed Linux drivers for the bamboo ink stylus. It is connected via bluetooth and on the bluetooth menu it is listed as a generic input device. My Xorg configurations are the default for Ubuntu 17.04. Here are my system specifications:
Laptop Model: Dell Inspiron 13-7378
OS Version: Ubuntu 17.04
CPU Model: Intel Core i5-7200U CPU @ 2.50GHz x 4
GPU Model: Intel HD Graphics 620 (Kabylake G2)
Memory: 7.7 GB
OS Type: 64-bit
Disk Size: 251.0 GB
Settings Changed from Default: Display scale set to 1.25
Non-default application installs:
  • Krita
  • Gimp
  • Pitivi
  • Google Chrome
  • Oracle JVM 8
  • GCC and Binutils
  • All requirements for the above
Default Applications Removed:
  • Firefox
Additional Drivers Enabled:
  • Processor Microcode firmware for Intel CPUs from intel-microcode
getynge
This is a bug in the wacom kernel module which has already been fixed in the upstream repository of the wacom-input project.
Commit message for the bugfix
Unfortunately the fix hasn't even made it into Ubuntu 18.04. But fortunately it is straight forward to update the kernel module yourself:
  1. Download and extract the last release of the input-wacom kernel driver from the github page:
    wget https://github.com/linuxwacom/input-wacom/releases/download/input-wacom-0.39.0/input-wacom-0.39.0.tar.bz2
    tar xf input-wacom-0.39.0.tar.bz2
  2. Build and install the module:
    cd input-wacom-0.39.0
    ./configure && make && sudo make install
  3. Reload wacom modules:
    sudo rmmod wacom
    sudo rmmod wacom_w8001
    sudo modprobe wacom
    sudo modprobe wacom_w8001
(Installation instructions taken from https://github.com/linuxwacom/input-wacom/wiki/Installing-input-wacom-from-source)
I did not find the solution myself, but this guy did: https://johnbintz.com/blog/2017-12-31-ubuntu-linux-wacom-pen-prox-click/
