My system is running on a AWS EC2 instance. Basic micro instance. I run the command:
sudo apt-get update
everything appears to be okay...and now
sudo apt-get upgrade
this is where I get this return message
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
   linux-headers-4.4.0-87-generic : Depends: linux-headers-4.4.0-87 but it is
not installed
E: Unmet dependencies. Try using -f.
and then this...
root@ip-172-31-18-25:/# apt-get install -f
Correcting dependencies... Done
The following packages were automatically installed and are no longer
required:
  libecap3 libltdl7 linux-headers-4.4.0-51 linux-headers-4.4.0-51-generic
  linux-headers-4.4.0-53 linux-headers-4.4.0-53-generic linux-headers-4.4.0-57
  linux-headers-4.4.0-57-generic linux-headers-4.4.0-59
  linux-headers-4.4.0-59-generic linux-headers-4.4.0-62
  linux-headers-4.4.0-62-generic linux-headers-4.4.0-63
  linux-headers-4.4.0-63-generic linux-headers-4.4.0-64
  linux-headers-4.4.0-64-generic linux-headers-4.4.0-66
  linux-headers-4.4.0-66-generic linux-headers-4.4.0-70
  linux-headers-4.4.0-70-generic linux-headers-4.4.0-71
  linux-headers-4.4.0-71-generic linux-headers-4.4.0-72
  linux-headers-4.4.0-72-generic linux-headers-4.4.0-75
  linux-headers-4.4.0-75-generic linux-headers-4.4.0-78
  linux-headers-4.4.0-78-generic linux-headers-4.4.0-79
  linux-headers-4.4.0-79-generic linux-image-4.4.0-51-generic
  linux-image-4.4.0-53-generic linux-image-4.4.0-57-generic
  linux-image-4.4.0-59-generic linux-image-4.4.0-62-generic
  linux-image-4.4.0-63-generic linux-image-4.4.0-64-generic
  linux-image-4.4.0-66-generic linux-image-4.4.0-70-generic
  linux-image-4.4.0-71-generic linux-image-4.4.0-72-generic
  linux-image-4.4.0-75-generic linux-image-4.4.0-78-generic
  linux-image-4.4.0-79-generic snap-confine
  Use 'apt autoremove' to remove them.
  The following additional packages will be installed:
  The following NEW packages will be installed:
 0 upgraded, 1 newly installed, 0 to remove and 56 not upgraded.
 8 not fully installed or removed.
 Need to get 0 B/9,892 kB of archives.
 After this operation, 70.6 MB of additional disk space will be used.
 Do you want to continue? [Y/n] y
 (Reading database ... 513496 files and directories currently installed.)
 Preparing to unpack .../linux-headers-4.4.0-87_4.4.0-87.110_all.deb ...
  Unpacking linux-headers-4.4.0-87 (4.4.0-87.110) ...
  dpkg: error processing archive /var/cache/apt/archives/linux-headers-
  4.4.0-87_4.
 4.0-87.110_all.deb (--unpack):
  unable to create '/usr/src/linux-headers-4.4.0-
  87/arch/x86/include/asm/alternat
  ive-asm.h.dpkg-new' (while processing './usr/src/linux-headers-4.4.0-
  87/arch/x86
  /include/asm/alternative-asm.h'): No space left on device
  No apport report written because the error message indicates a disk full error
        dp
  kg-deb: error: subprocess paste was killed by signal (Broken pipe)
  /var/cache/apt/archives/linux-headers-4.4.0-87_4.4.0-87.110_all.deb
Yes, I realize it says disk is full, however it is in fact not even close to being full...
  root@ip-172-31-18-25:/# df -Th
  Filesystem     Type      Size  Used Avail Use% Mounted on
  udev           devtmpfs  487M     0  487M   0% /dev
  tmpfs          tmpfs     100M  3.0M   97M   4% /run
  /dev/xvda1     ext4      7.8G  4.4G  3.1G  59% /
  tmpfs          tmpfs     496M     0  496M   0% /dev/shm
  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
  tmpfs          tmpfs     496M     0  496M   0% /sys/fs/cgroup
  tmpfs          tmpfs     100M     0  100M   0% /run/user/1000
Edit:
I checked the df -i and it said boot was full. I was sick of this problem so I just ended up terminating the instance. I have terminated many instances on aws ec2, seems like I was forever running into problems. Seems like you need to have a IT/Server specialist to host a simple website, disgusting. Why Ubuntu developers?? Was it because I was running
   sudo apt-get
instead of
   sudo apt
what a nuisance. it shouldn't be this hard.
pa4080
  • 30,621
