I mistakenly dpkg-ed libfontconfig1 on Ubuntu 16.04 by running following command:
sudo dpkg -i ~/Downloads/libfontconfig1_2.12.3-0.2_amd64.deb
And now it conflicts with previously installed libfontconfig1. Following the list:
$sudo dpkg --list libfontconfig1
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
rU libfontconfig1:amd64 2.12.3-0.2 amd64 generic font configuration library - runtime
iF libfontconfig1:i386 2.11.94-0ubuntu1.1 i386 generic font configuration library - runtime
And I'm not able to remove it because seems it's a major package and is a dependency for many other packages: all of them require a version (which is lower than 2.12.3-0.2) or greater version. And seems because of or greater condition, the version 2.12.3-0.2 is being blocked for removal, even though I have other version installed. When I run
sudo apt-get purge libfontconfig1:amd64
It doesn't allow me, because many things depends on lower or equal version of the package:
firefox : Depends: libfontconfig1 (>= 2.11.94) but it is not going to be installed
libbluray1 : Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed
libcairo2 : Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed
Removing through dpkg also not helpful:
$sudo dpkg --remove libfontconfig1:amd64
libqtwebkit4:amd64 depends on libfontconfig1 (>= 2.9.0).
openjdk-8-jre-headless:amd64 depends on libfontconfig1.
libclutter-1.0-0:amd64 depends on libfontconfig1 (>= 2.9.0).
fontconfig depends on libfontconfig1 (>= 2.11.94).
dpkg: error processing package libfontconfig1:amd64 (--remove):
dependency problems - not removing
When I run sudo apt-get -f install I get following result:
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
libfontconfig1: Depends: fontconfig-config (>= 2.12.3-0.2) but 2.11.94-0ubuntu1.1 is installed
Breaks: libfontconfig1:i386 (!= 2.12.3-0.2) but 2.11.94-0ubuntu1.1 is installed
libfontconfig1:i386 : Breaks: libfontconfig1 (!= 2.11.94-0ubuntu1.1) but 2.12.3-0.2 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
So, how do I remove a particular version of libfontconfig1 package?
Appreciate any help.
