I'm working through this and this tutorials from DigitalOcean and trying to set up an ssh connection on port 443 as per step 5. I've been able to get it working on port 22 (steps 1-4). I've checked the firewall and port 443 is open. I've changed the /etc/ssh/sshd_config file to:
# What ports, IPs and protocols we listen for
Port 22
Port 443
I've restarted the service:
sudo service ssh restart
sudo service sshd restart
When I login with putty on port 443 I get a blank screen. It works on port 22. Anything else I can do to get this working on port 443?
Edit:
$ sudo lsof -i -n -P +c 0 | grep ':80\|:443'
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nginx 26964 root 6u IPv4 2603510992 0t0 TCP *:80 (LISTEN)
nginx 26964 root 7u IPv6 2603510993 0t0 TCP *:80 (LISTEN)
nginx 26964 root 8u IPv4 2603510994 0t0 TCP *:443 (LISTEN)
nginx 26965 www-data 6u IPv4 2603510992 0t0 TCP *:80 (LISTEN)
nginx 26965 www-data 7u IPv6 2603510993 0t0 TCP *:80 (LISTEN)
nginx 26965 www-data 8u IPv4 2603510994 0t0 TCP *:443 (LISTEN)
Edit:
$ sudo systemctl status sshd
● ssh.service - OpenBSD Secure Shell server
Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2017-09-07 16:04:13 EDT; 1min 19s ago
Main PID: 22845 (sshd)
CGroup: /system.slice/ssh.service
├─22103 sshd: deploy [priv]
└─22853 pager
Sep 07 16:04:13 server sshd[22845]: error: Bind to port 443 on 0.0.0.0 failed: Address already in use.
Sep 07 16:04:13 server sshd[22845]: Server listening on 0.0.0.0 port 22.
