all,
I have found that the same Makefile works well in Mac OS X, but does not work in Ubuntu. The snippet is as following:
start:
    @echo $(seperator)
    @if [[ "$(PROJECT)" == "" ]]; then \
         echo " Project powered by CodeMate!"; \
     else \
         echo "  $(PROJECT)"; \
     fi
    @echo $(seperator)
and make complains:
/bin/sh: [[: not found
Any idea?
Cheers,
Li
Updates:
I have changed the above conditional Bash statements to:
if test "$(PROJECT)" = ""; then \
then things work fine. So what is wrong with "[["?
Li Dong
  • 173
Place this at the top of your Makefile:
SHELL := /bin/bash # Use bash syntax
This happens because [[ is a builtin command of bash and you're running it with sh. The above line will set bash as default interpreter for the commands ran on makefile.
0x2b3bfa0
  • 9,110
  • 38
  • 55
Robin Winslow
  • 2,646
  • 26
Makefiles use sh by default, not bash.
In Ubuntu sh point to dash, a POSIX compliant and minimalistic shell, not providing the [[ keywork.
enzotib
  • 96,093
