Sorry for my bad English
My problem is screen tearing in Lubuntu 16.04, my GPU is Intel HD graphic
I install compton and this command help me
$ compton -b --vsync opengl
But I want to auto start compton so I search the Internet for this.
I edit the file
/etc/xdg/lxsession/Lubuntu/autostart by adding this line @compton -b --vsync opengl
But it do not work, can anyone help me?
$ which compton
/usr/bin/compton
$ sudo systemctl status mycompton.service
● mycompton.service - compton autostart script
Loaded: loaded (/etc/systemd/system/mycompton.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since T5 2017-09-07 15:59:44 ICT; 5s ago
Process: 6342 ExecStart=/usr/bin/compton -b --vsync opengl (code=exited, status=1/FAILURE)
Th09 07 15:59:44 GaCon systemd[1]: Failed to start compton autostart script.
Th09 07 15:59:44 GaCon systemd[1]: mycompton.service: Unit entered failed state.
Th09 07 15:59:44 GaCon systemd[1]: mycompton.service: Failed with result 'exit-code'.
Th09 07 15:59:44 GaCon systemd[1]: mycompton.service: Service hold-off time over, scheduling restart.
Th09 07 15:59:44 GaCon systemd[1]: Stopped compton autostart script.
Th09 07 15:59:44 GaCon systemd[1]: mycompton.service: Start request repeated too quickly.
$ journalctl -xe
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit mycompton.service has finished shutting down.
Th09 07 15:59:44 GaCon systemd[1]: Starting compton autostart script...
-- Subject: Unit mycompton.service has begun start-up
-- Unit mycompton.service has begun starting up.
Th09 07 15:59:44 GaCon compton[6342]: session_init(): Can't open display.
Th09 07 15:59:44 GaCon systemd[1]: mycompton.service: Control process exited, code=exited status=1
-- Subject: Unit mycompton.service has failed
-- Unit mycompton.service has failed.
-- The result is failed.
-- Subject: Unit mycompton.service has finished shutting down
Th09 07 15:59:50 GaCon sudo[6344]: lhv : TTY=pts/0 ; PWD=/home/lhv ; USER=root ; COMMAND=/bin/systemctl status mycompton.service
Th09 07 15:59:50 GaCon sudo[6344]: pam_unix(sudo:session): session opened for user root by (uid=0)
Th09 07 15:59:50 GaCon sudo[6344]: pam_unix(sudo:session): session closed for user root
Th09 07 16:00:14 GaCon com.canonical.indicator.application[974]: (process:1199): indicator-application-service-WARNING **: Application already exists, re-requesting pro
lines 2628-2669/2669 (END)
