Due to my ISP intercepting some DNS requests and return 'redirected' A records, I want to use dnscrypt-proxy on my computer (my workstation, actually, running Ubuntu 16.04)
What I have done is install dnscrypt-proxy and point it to one of the public dnscrypt servers available. Then I change the DNS Server settings in Network Manager to point to 127.0.2.1 (the default listening address of dnscrypt-proxy)
It works, but it seems that every single resolve of FQDN goes to the dnscrypt server, and no caching is being performed.
So, I want to cache DNS resolution done by dnscrypt. I know I can do this using unbound, but dnsmasq is already installed on my workstation, so I want to use that instead. However, I'm a bit confused with the interaction between dnsmasq & resolvconf & Network Manager.
That leads to My Questions:
How do I configure my system so DNS Resolution will be done by dnscrypt-proxy but cached by dnsmasq?
pepoluan
  • 775
You should first edit the NetworkManager config file in /etc/NetworkManager/NetworkManager.conf and change the line that says dns=dnsmasq to dns=none. Then restart the NetworkManager service using sudo systemctl restart NetworkManager.
Install dnsmasq with sudo apt update && sudo apt install dnsmasq -y. Edit the dnsmasq config in /etc/dnsmasq.conf using your preferred editor.
Delete the whole config, and replace it with this:
listen-address=127.0.0.1
port=53
domain-needed
bogus-priv
dnssec
proxy-dnssec
strict-order
no-resolv
no-poll
server=127.0.2.1
cache-size=1000
neg-ttl=3600
dns-forward-max=150
bind-interfaces
Then, stop and disable resolvconf using sudo systemctl stop resolvconf && sudo systemctl disable resolvconf and restart and enable dnsmasq using sudo systemctl restart dnsmasq && sudo systemctl enable dnsmasq. Edit /etc/resolv.conf using your preferred editor. Change it to only have one line:
nameserver 127.0.0.1
Now, test your internet connection by pinging a web address, for example google.com. If you get a response, it means that your setup is working!
Mutantoe
  • 107
