16
"Spotify for linux" doesn't show up in default applications menu for Music (system info section in system settings).
Therefore, it also doesn't come in Dash and music media keys don't work as well.
How to make it the default application for playing Music or make media keys work?
hemanv2
  • 163
5 Answers5
10
Don't have spotify so can only answer question 1 generally
The 'Default music player', or 'Listen to Music' in the Dash is set by whatever app is the default application for audio/x-vorbis+ogg
That is the extent of the usefulness to setting a default music player in System Settings > System Info > Default Applications > Music
To use a player that doesn't show up in the above setting's dropdown list there are 2 ways, most direct, in all cases the app must have a .desktop, in this case maybe spotify.desktop
gedit ~/.local/share/applications/mimeapps.list
In the [Default Applications] section look for this line
 audio/x-vorbis+ogg=
If it's there replace the whatever.desktop with the whatever.desktop of your choice, otherwise just add the line, Example - I've set audacious, you'd be using spotify.desktop if it exists
audio/x-vorbis+ogg=audacious2.desktop
Additionally you may want to add that whatever.desktop to the end of the same line in [Added Associations], same example, note that entries in Added end with ;
audio/x-vorbis+ogg=vlc.desktop;audacious2.desktop;
The other thing that can be done is to open your app's .desktop file in a text editor, in this case possibly spotify.desktop
Add a %U to the end of the Exec= line, again using as an Example audacious
Exec=audacious2 %U
Also look for a MimeTypes= line & see if there is this entry, audio/x-vorbis+ogg;
If not then just add to end of line
doug
  • 17,212
As doug suggested, simply add this line to your ~/.local/share/applications/mimeapps.list file in two places, like so:
audio/x-vorbis+ogg=spotify.desktop
audio/x-vorbis+ogg=spotify.desktop;
After doing this, Spotify instantly showed up as my default music played in Unity.
Cheers!
In trying to make this work in Ubuntu 21.04 (yes hirsute hippo) I notice there is a mimeapps.list in ~/.config but none in ~/.local/share/applications.
I made the change there (in my case I wanted to make Cantata the default) as per the instructions given and it worked just fine.
In 18.04 I added those lines to /usr/share/applications/mimeapps.list [New File]
Works like a charm! Now I can finally skip using keyboard shortcuts.
Doug's answer works well. I wanted to add that the .desktop file for spotify is now spotify_spotify.desktop and my ~/.local/share/applications/mimeapps.list file looks like this:
audio/x-vorbis+ogg=spotify_spotify.desktop
audio/x-vorbis+ogg=spotify_spotify.desktop;
ssohin
