Is there any application which can manipulate time and date for any specific application? If I change date and time of system then browser can't let me access internet. Any help will be appreciated. Thank you
Mihir
  • 41
You can use faketime to tell processes it's a different time.
Install it via:
sudo apt install faketime
Then just run your application like this:
faketime -f '-5d' date
This calls date. So just substitute date with whatever you like.
The example goes 5 days back change that part to whatever you like.
If you want to learn more about how you can use faketime, check out its man page:
man faketime
Note that this only works after you installed it.
If you're curious how to achieve this for an application you launch from the Dash, check out this answer.
UTF-8
  • 5,910
  • 34
  • 68
