33
I want to rearrange the pages in a PDF file. But because I have to rearrange many pages, and the new arrangement has a specific pattern, I would like to do so with a script. Is there a simple program which allows to rearrange the pages in a PDF?
Alternatively I could also extract all pages and merge them together in the order I want. What progams are available to do this?
red_trumpet
  • 1,969
pdftk is the one you're searching for. E.g. if you want to reverse the page order of i.pdf, do
pdftk i.pdf cat end-1 output o.pdf
Other examples showing pdftk's potential:
pdftk i.pdf cat 4-1 6 8-end output o.pdf # use ranges
pdftk i.pdf cat 1-6even output o.pdf     # print only even pages in the range
pdftk i.pdf cat 1-10 ~5-7 output o.pdf   # exclude pages in the range
pdftk i.pdf burst                        # extract to single-page pdf files
Read man pdftk for more information.
To install pdftk on 18.04 see: How can I install pdftk in Ubuntu 18.04 Bionic?
If you after all search for a GUI solution have a look at pdftk's GUI pdfchain or pdfmod.
dessert
  • 40,956
You can use qpdf which comes with ubuntu. This following command for example puts the pages in reverse order.
qpdf --empty --pages infile.pdf z-1 -- outfile.pdf
You can find more information and other examples here on pages 10 and 11.
SaTa
  • 1,036
You can also try pdfjam pdfnup (based on LaTeX pdf-pages)
Example:
pdfjam i.pdf '{},2,1-5'         -o o.pdf
pdfjam f1.pdf f2.pdf f3.pdf 1-3 -o o.pdf   ## first 3 pages from f1,f2,f3
  • {} inserts an empty page
  • many options available (ex: scale, offset, trim, frame, nup) -- see pdfjam man
dessert
  • 40,956
qpdf works like a charm (tested under cygwin, don't say it), preserving the links within the pdf required me to not use the --empty option and to replace it with the input filename:
qpdf input.pdf --pages input.pdf 1,4,5,7-r8,2,3,r7-z -- output.qpdf.pdf
(rN to select a page indexed from end, z for last page)
