I'm setting up a transparent proxy/filter server, I've encountered many issues.
My Question. With a PPPOE DSL modem how do I negotiate a connection from my server. I am putting the server between the modem and the router (now just a switch and wifi AP)
The router did the PPPOE login for me.
My modem can be put into the following modes. PPPOE on modem, PPPOE on computer(router), & bridge.
I thought I could connect to the modem with a static IP with my 2nd NIC with the PPPOE on the modem. This didn't seem to work. For example the modem's ip is 192.168.0.1 so I set a static IP of 192.168.0.2 This has worked in the past to connect and configure the modem.
Any help would be great!
Jorge Castro
  • 73,717
M J
  • 71
You probably need your server up to do the pppoe authentication. Look at these instructions. I think they will help you to do this,
txwikinger
  • 29,406
Maybe you will need the pppoeconf command.
