When I try the following code :
import Tkinter
Tkinter._test()
I get the following error :
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 3835, in _test
    root = Tk()
  File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1818, in __init__
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: Can't find a usable tk.tcl in the following directories:
/usr/local/lib/tcl8.6/tk8.6 /usr/local/lib/tk8.6 /usr/lib/tk8.6 /usr/lib/tk8.6 /lib/tk8.6 /usr/library
This probably means that tk wasn't installed properly.
I tried to reinstall Tkinter, but it still give the same error.
Can I have help please ?
Install python-tk and I think you will solve your problems.
sudo apt-get install python-tk
ubfan1
  • 19,049
Tkinter has a different name in Python 2 and 3.
  • Python 2: import Tkinter
  • Python 3: import tkinter
Unless you have a very good reason, use Python 3. Make sure tkinter is installed by running sudo apt-get install python3-tk and use the python3 command in the terminal.
Timo
  • 4,700
