Install OpenCL on Ubuntu 17.04, Intel
I'm trying to install OpenCL on ubuntu 17.04 with:
$ lshw :
     *-cpu
          product: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
          vendor: Intel Corp.
          physical id: 1
          bus info: cpu@0
          capacity: 3100MHz
          width: 64 bits
        *-display
             description: VGA compatible controller
             product: 3rd Gen Core processor Graphics Controller
             vendor: Intel Corporation
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 09
             width: 64 bits
             clock: 33MHz
             capabilities: vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:34 memory:a0000000-a03fffff memory:90000000-9fffffff ioport:2000(size=64) memory:c0000-dffff
So far, haven't been able to find any docs. Intel's "install.sh" reports unsupported OS.
---- As per @Thomas, I've installed: apt-get install beignet clinfo
So far there does not seem to be opencl gpu support
Here is the clinfo output:
$ clinfo :
Number of platforms                               1
  Platform Name                                   Intel Gen OCL Driver
  Platform Vendor                                 Intel
  Platform Version                                OpenCL 2.0 beignet 1.3
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_spir cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short
  Platform Extensions function suffix             Intel
beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware
(If you have multiple ICDs installed and OpenCL works, you can ignore this message)
Number of devices                                 0
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Intel Gen OCL Driver
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Intel Gen OCL Driver
  clCreateContext(NULL, ...) [default]            No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No devices found in platform
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.11
  ICD loader Profile                              OpenCL 2.1
Thomas
  • 6,433
You can install beignet package for use with Intel, and clinfo will be helpful to check what is recognized.
Then run clinfo to check the openCL devices.
clinfo
Depending on your plans, you also might want to have to install development packages or other libraries as well.
apt-get install beignet-dev
For libraries or programmes you are interested in use the command as follows to find them.
apt-cache search opencl
Thomas
  • 6,433
