This is very much like the question at "How to use gps receiver bu-353" except that answer didn't get me all the way there.
I am trying to connect a BU-353-S4 by GLOBAL-SAT for use with OpenCPN. I can get the receiver to work in gpsmon, not in xgps, cgps or OpenCpn. Does anyone know how to get it to work in openCPN?
Output of: ls
ls /dev/ttyUSB
/dev/ttyUSB0
Output of: gpsd -n -N -D 2 /dev/ttyUSB0
gpsd:ERROR: can't bind to IPv4 port gpsd, Address already in use
gpsd:ERROR: maybe gpsd is already running!
gpsd:ERROR: can't bind to IPv6 port gpsd, Address already in use
This is after I removed and reinstalled gpsd & gpsd-clients, but before I re-started gpsd.
user68186
  • 37,461
This cured my problem:
I stumbled on to another forum that said to try changine the default settings for gpsd at [/etc/default/gpsd] to this.
# Default settings for the gpsd init script and the hotplug wrapper.
Start the gpsd daemon automatically at boot time
START_DAEMON="false"
Use USB hotplugging to add new USB devices automatically to the daemon
USBAUTO="true"
Devices gpsd should collect to at boot time.
They need to be read/writeable, either by user gpsd or the group dialout.
DEVICES="/dev/ttyUSB0"
Other options you want to pass to gpsd
GPSD_OPTIONS="-n -G -b" GPSD_SOCKET="/var/run/gpsd.sock"
end of file gpsd
to my surprise it worked.
