-1
How can i access the Linux machine remotely ? That means i want to access my friend laptop which is booted with ubuntu16.04, and my laptop also booted with ubuntu16.04. what and all softwares i want install and send the procedure too
muru
  • 207,228
  1. I think you would like to access your friends machine via GUI. Just install TeamViewer (Internet Must) on both machines. Then you required Teamviewer ID and password from your friends machine, then you can access your friends machine remotely with GUI.
  2. If both computers are not connected to the Internet but are connected to LAN, you can enable the remote desktop of the machine and access the machine remotely. Info to enable
  3. If you want to access only the command line, you must install openssh-server on both machines, and then you will be able to access the command line. (LAN, Disable firewall must)
Rakesh C
  • 316
