I'm a rookie programmer and trying to compile a C code in Ubuntu. I already installed GCC. How do I proceed from here?
pa4080
  • 30,621
You can compile from following command :
$ gcc -o object-file C-source-file
Then try to run :
$ ./object-file
For C code you can use cc command too also you can use g++ for C++.
Once your code becomes more complicated and you start using more and more files, the above will become cumbersome and you'll want to look into "makefiles". They work for small projects too, so the sooner you become familiar with them, the better. If you later code in C++, you will also likely use these.
Ali Ghasempour
  • 449
or you can compile your f.c file from console:
gcc f.c -Wall
then run :
./a.out
Chai T. Rex
  • 5,323
Adam
  • 379
In a terminal (press Ctrl+Alt+T to open one):
  1. Change the directory to where you have saved the .c file using
    cd path
    command
  2. Type the following command and change the fileName with yours
    gcc -o c-fileName fileName.c
    You can write any name instead of c-fileName.
  3. Then to run your file type
    ./c-fileName
    in terminal.
Chai T. Rex
  • 5,323
