I just installed net-snmp on Ubuntu 16.04 from sources using this tutorial (downloaded 5.7 patch), and when calling
$ snmpget --version
NET-SNMP version 5.7.3
$ whereis snmpd
snmpd: /usr/local/sbin/snmpd
so it has been installed. However, when I want to check if snmpd is running
sudo service snmpd status
it returns Loaded: not-found (Reason: No such file or directory) Active: inactive (dead). When I try to start snmpd
sudo service snmpd start
it returns Failed to start snmpd.service: Unit snmpd.service not found. When starting it directly from command line
$ snmpd
snmpd: symbol lookup error: snmpd: Undefined symbol: netsnmpd_close_fds
The other problem is that the /etc/snmp/ directory does not exist, which should contain the snmpd.conf file that I need to edit.
I never had these kinds of problems when I was using the
sudo apt-get install snmpd
but I must use sources to configure the installation with options that do not come with the 'apt-get' installation. What am I doing wrong?
Nazar
  • 155
Remove the snmp:
sudo apt-get -y autoremove snmp
Install again like this:
sudo apt-get update -y
sudo apt-get upgrade -y
Remove any unnecessary files shown in the system:
cat /etc/snmp/snmpd.conf
systemctl restart snmpd
systemctl enable snmpd
systemctl status snmpd
zx485
  • 2,865
