37
I am unable to visit most sites online in either firefox or chrome. I can access google docs so I am researching on windows 7 (dualboot) and rebooting into Ubuntu (recently upgraded to 16.04).
Test 0:
$ sudo /etc/init.d/dns-clean
(nothing happened)
Test 1:
$ dig microsoft.com
; <<>> DiG 9.10.3-P4-Ubuntu <<>> microsoft.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 2944
;; flags: qr rd ra; QUERY: 1, ANSWER: 5, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;microsoft.com.         IN  A
;; ANSWER SECTION:
microsoft.com.      896 IN  A   104.43.195.251
microsoft.com.      896 IN  A   23.100.122.175
microsoft.com.      896 IN  A   23.96.52.53
microsoft.com.      896 IN  A   191.239.213.197
microsoft.com.      896 IN  A   104.40.211.35
;; Query time: 102 msec
;; SERVER: 2001:558:feed::1#53(2001:558:feed::1)
;; WHEN: Tue Aug 29 14:54:43 EDT 2017
;; MSG SIZE  rcvd: 122
Test 2:
$ ping reddit.com
connect: Network is unreachable
Test 3:
$ less /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
Test 4:
$ less /etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile,ofono
/#dns=dnsmasq
no-auto-default=D4:BE:D9:A6:2E:C1,
[ifupdown]
managed=false
Test 5: Chrome
This site can’t be reached
www.reddit.com’s server DNS address could not be found.
DNS_PROBE_FINISHED_NXDOMAIN
Test 6: Firefox
Server not found
Firefox can’t find the server at www.reddit.com.
Check the address for typing errors such as ww.example.com instead of www.example.com
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Edit: Almost forgot, this seems to have started after I tried installing PlayOnLinux the other day. I uninstalled it but the problems persist.
Any thoughts?
Re: possible duplicate question : dns_probe_finished_nxdomain error caused by Ubuntu dns_probe_finished_nxdomain error caused by Ubuntu I clearly state in my question that the solution posed in the other thread of clearing the dns cache does not resolve my issue.
Nick S
  • 472
7 Answers7
80
Resolved: DNS_PROBE_FINISHED_NXDOMAIN in Linux
Step 1. Open terminal and add below command
sudo nano /etc/dhcp/dhclient.conf
Step 2. Now add below line in file
supersede domain-name-servers 8.8.8.8;
Now, save file
Step 3. Restart the network
sudo service network-manager restart
or
sudo systemctl restart NetworkManager.service
Refresh your page and done.
For me (Ubuntu 20.04), the only working solution was to add DNS servers of Google and OpenDNS.
I did it at computer level:
sudo vim /etc/resolv.conf
And added these lines (before other nameservers):
nameserver 8.8.8.8
nameserver 208.67.222.222
nameserver 4.2.2.2
To make these changes permanent, follow this: how to change DNS server permanently on Ubuntu 20.04?
This can be also done at router level (for all devices):
  • Go to router management -> DNS -> Set primary DNS to 8.8.8.8 and secondary DNS to 208.67.222.222.
See https://linuxhint.com/opendns-vs-googledns/ for more info about choosing the DNS nameservers (and checking which server is faster in your location).
For me it was flushing the dns cache that way:
sudo systemd-resolve --flush-caches
You can then check the statistics in order to make sure that your cache size is now zero.
sudo systemd-resolve --statistics
Aziz.G
  • 171
Restarting the router solved this problem for me.
talz
  • 195
I am having the same issue. I have tried everything from all answers and none of these work for me. I am working right now on something which requires a lot of DNS updates and this completely blocks my work all the time. I have to go and look at the site on my phone / ipad to see if it is really working.
Is there any other possible solution ?
In my case I solved it from TpLink router -admin panel settings.
Go to Advance > Network > LAN settings, and change:
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Hit save then restart your router, wait to see your internet indicator lights up on your router and then reload your pages to check.
Jood80
For me below command worked in Ubuntu:
  1. Open Terminal
  2. Type sudo dhclient -r and hit enter. It will give result "Killed old client process"
  3. Type sudo dhclient and hit enter. It will assign new IP to your system
  4. Reload the site.
