I accept that it's standard to convert <tag></tag> to <tag/> but the client wants it in the former layout, not the latter. I've looked at various options for xmllint and cannot figure out what's needed.
Alternatively, is there something else other than xmllint that could be used?
buddemat
  • 487
bugmagnet
  • 327
xmllint has options that can be used to produce the desired output. From the help:
--c14n : save in W3C canonical format v1.0 (with comments)
--c14n11 : save in W3C canonical format v1.1 (with comments)
--exc-c14n : save in W3C exclusive canonical format (with comments)
Using any one of these would work
xmllint --c14n test.xml
Unfortunately, combining several formatting options in one xmllint call does not seem to work, so if you e.g. additionally want to use --format to have xmllint reformat/reindent the output, you will need to pipe the output from the first xmllint call into a second one. When doing this, it seems that xmllint requires the - stdin redirect be at the end of the command.
Example:
For test.xml as
<?xml version="1.0" encoding="UTF-8"?>
<outer><inner/></outer>
the command
xmllint --format test.xml | xmllint --c14n -
produces the output
<outer>
  <inner></inner>
</outer>
Notes:
  • since the --format option would collapse the expanded empty tag again, the order of the options in the pipe matters
  • the above options remove the xml declaration / omit it in the first line of the output
buddemat
  • 487
