I faced this humongous Chrome UI problem and stumbled upon this question on superuser, which uses the same Ubuntu version. I have followed the accepted answer there but apparently it does not have any effect. Is there a new workaround for this issue?
My display is not a HiDPI one, it is 1366x768, scaling factor is set at 0.875 in order to make text the same size as in Windows. Every other program follows this scaling, except Chrome.
Nur
  • 4,131
  1. Remove Chrome completely as described here
  2. Set the system-wide font size to desired value (if it is already the desired value, change it to something else, reboot, then change to the size you want)
  3. Reboot
  4. Install Chrome again
Chrome will respect the system-wide font size this way. The rebooting might be unnecessary, but it doesn't work for me without rebooting first after changing font.
Nur
  • 4,131
