Earlier today I was trying to shrink and move a partition when gparted totally froze. (not the main os partition) After waiting about 4 hours I force shutdown my computer. Now when I look at the partition in gparted it looks like this and this. As you can see, some part within the partition space is apparently unallocated. I can't mount, shrink, move or otherwise change the partition. Checking it with gparted throws an error. What can I do? (/dev/nvme0n1p8 is the affected partition)
EDIT: e2fsck:
sudo e2fsck /dev/nvme0n1p8
e2fsck 1.43.4 (31-Jan-2017)
/dev/nvme0n1p8 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Missing '.' in directory inode 510513.
Fix<y>? yes
Setting filetype for entry '.' in ??? (510513) to 2.
Missing '..' in directory inode 510513.
Fix<y>? yes to all
Setting filetype for entry '..' in ??? (510513) to 2.
Entry 'S3J5cHRpYy50dGY=.png' in ??? (510513) has deleted/unused inode 6166343. Clear? yes
Entry 'RnJlaWdodFRleHQgTGlnaHRTQy50dGY=.png' in ??? (510513) references inode 6167543 found in group 752's unused inodes area.
Fix? yes
ext2fs_read_inode: Inode checksum does not match inode while reading inode 6167543 in check_filetype
/dev/nvme0n1p8: ***** FILE SYSTEM WAS MODIFIED *****
e2fsck: aborted
EDIT fdisk -l (/dev/nvme0n1p8 is the affected partition)
ubuntu-gnome@ubuntu-gnome:~$ sudo fdisk -l
Disk /dev/loop0: 1.4 GiB, 1462083584 bytes, 2855632 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 03DB32A6-DAC5-46B5-8138-C9F14617A1FB
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1026047 1024000 500M EFI System
/dev/nvme0n1p2 1026048 1288191 262144 128M Microsoft reserved
/dev/nvme0n1p3 1288192 46344191 45056000 21.5G Linux swap
/dev/nvme0n1p4 971556864 972503039 946176 462M Windows recovery environmen
/dev/nvme0n1p5 972503040 997814271 25311232 12.1G Windows recovery environmen
/dev/nvme0n1p6 997816320 1000214527 2398208 1.1G Windows recovery environmen
/dev/nvme0n1p7 46344192 513597439 467253248 222.8G Linux filesystem
/dev/nvme0n1p8 513597440 971556863 457959424 218.4G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/sda: 1.9 GiB, 2003828736 bytes, 3913728 sectors
Disklabel type: dos
Disk identifier: 0x782a20f2
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 0 2964415 2964416 1.4G 0 Empty
/dev/sda2 84608 89215 4608 2.3M ef EFI (FAT-12/16/32)
sudo df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 8108160 0 8108160 0% /dev
tmpfs 1624936 10352 1614584 1% /run
/dev/sda 1482208 1482208 0 100% /cdrom
/dev/loop0 1427840 1427840 0 100% /rofs
aufs 8124668 209576 7915092 3% /
tmpfs 8124668 84140 8040528 2% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 8124668 0 8124668 0% /sys/fs/cgroup
tmpfs 8124668 0 8124668 0% /tmp
tmpfs 1624932 60 1624872 1% /run/user/999
sudo mount -a produces no output
