How I can check Ubuntu server is in a security group that accepts inbound connections to specific IP address x.x.x.x ?
I am trying to use conjure-up to deploy kubernetes,
  1. I have MAAS Installed with 2 Nodes (both ready)
  2. I installed Conjure-up
  3. I Run conjure-up kubernetes, then used MAAS as a cloud
  4. After boot strapping one of the nodes and installing OS
  5. The porcess stuck and console shows the Attempting to connect to x.x.x.x:22
  6. x.x.x.x is the nodes is already up and running from step 4
  7. All setting is working under System proxy
After search for solution I found this:
When prompted, deploy all five remaining items. When you see "Juju Controller is initializing. Please wait." You may observe a delay on the step that says
Attempting to connect to x.x.x.x:22" You may want to make sure your Ubuntu server is in a security group that accepts inbound connections to the IP address x.x.x.x.
Rastin
  • 804
It seems it was a bug in juju 2.0.2.
  1. Installed snap juju
  2. sudo add-apt-repository ppa:juju/stable
  3. sudo apt update
  4. sudo apt install juju
Now with juju 2.2.2 : it worked!
Rastin
  • 804
