I have windows 10 and Ubuntu 14.04 dual booted on my device. I had re-installed Linux recently on the Linux partition. And when I re-installed it I accidentally set the /home partition to only 20 GB and I must have set the / partition as 120 GB. Now what I believe happened was that I made the home directory I had initially as the new root directory because after running Ubuntu I saw that I had an ext4 partition with some of my older files.
Well I didn't realise the mistake in the small size of the /home partition until sometime later. And then I searched on upon how to expand my home directory using GParted. So now I had this 120 GB of space which I though was just contained remnant user files from the previous Ubuntu installed. So I deleted the partition to make it unallocated space and then expanded my /home directory completely occupying that space. And now I am stuck at the grub recovery window on boot.
Again I am not sure if I had set the root on the 120 GB partition but that is my theory. And also if it is relevant I had a swap partition between the 20 GB and 120 GB partitions and after making the 120 GB unallocated I moved the swap partition to the end of the partition to bring the 20 GB and 120 GB spaces together. Below is the current partitions on the disk.
You deleted your /root partition. So your system can't find it during boot. You have to make a new root partition and then install the system again.
codedump
  • 126
