So, out of nowhere a 84MB Volume /dev/loop0 popped up. I don't know what it is or why it is there. I did recently install dropbox, Kdenlive, and VLC Media Player. Could one of those programs have caused this? Should I worry? I'm new to Linux. Should I get rid of this Volume, and if so how do I do that?
Check to see if you have any iso's or other special files "mounted" (look at your file browser on the left). They will usually create loop devices as special mounts.
No, you don't need to worry about it. They can be created by various programs, but 84MB is not large at all.
If you want more info, read this answer: What is /dev/loopx?
If you want to try to remove it for whatever reason, try umount /dev/loop0. You might need a sudo before umount depending on the device.
- 3,923
From man loop:
The loop device is a block device that maps its data blocks not to a physical device such as a hard disk or optical disk drive, but to the blocks of a regular file in a filesystem or to another block device.
As mentioned by Tom Yan, you can find the loop device's backing file (assuming it is indeed backed by a file and not another block device) with sudo losetup.
The file path/name might give you a hint as to which application it belongs to.
If it does not, you may have luck with dpkg -S <file>
- 444
